Part Numbering
Hello all,
TC automatic part numbering in NX is assigning incorrect part numbers.  Typically, when starting a new model you click "assign" for the part number, and it gives us a uniform part number.  Example:  ABC0000123, ABC0000124.  Now its just assigning a random 6 digit number not matching our standard.  This has happened from time to time on a few of our workstations at random.  Typically goes away after a restart.  Still have not been able to figure this out.
has anyone experienced this before?
Jake
Re: Part Numbering
Maybe the item type was changed.
This can happen when the template (pax) files are not available/accessible  when user presses the New command.
Re: Part Numbering
Have you defined the Naming rule for this particular Item Revison in BMIDE ?
Teamcenter 10.1.7
TC Visualization 10.1.7
NX:11.02 | NX 9.02 | Catia V5 R2012 | AutoCAD 2018 | In-Context Editor |
Re: Part Numbering
I am not sure.  The particular machine was recently assigning part numbers properly.  The naming rule should not have changed.
Jake
