Participant propagation on change objects
Hi everyone,
I'm wondering if if the participants set in Problem Report can also appear in the Change Request when the PR is derived in the ECR.
Maybe my question is simply how can propagate a property when a change item is derived ?
Thank you in advance for any guidance Smiley Happy,
Best regards.
Benjamin
Re: Participant propagation on change objects
In case someone wants to know what I did, I create a compound property solve my issue going through the implements link and pointing on the participant property of the previous item.
It made me recover the participant as I wanted.
