Perspective names
Where in the documentation does it list perspective names?
I'm trying to change the default perspective to "My Teamcenter". If I add the line
-perspective com.teamcenter.rac.myteamcenter.MyTeamcenterPerspective
to Teamcenter.ini it doesn't change the default probably because it's called something different.
Using Teamcenter 8.3
4 REPLIES 4
Re: Perspective names
You need to use:
-perspective com.teamcenter.rac.ui.perspectives.navigatorPerspective
Thanks and Regards
Yogesh Fegade
I added that into my Teamcenter.ini and it still isn't defaulting to it on launch. Perhaps there is a stronger default somewhere else. I'll have to do some more troubleshooting. Thanks for the answer! I'll accept once I get it working, just got some other things to do first.
This is how we start our Teamcenter client:
start /WAIT Teamcenter.exe -perspective com.teamcenter.rac.ui.perspectives.navigatorPerspective %*
Check your Teamcenter.ini file.
What does it default to?
Thanks and Regards
Yogesh Fegade
Thanks, setting it in the cmd line worked for me!
