Pool ID to start up not provided
I am getting below issue with .Net Server manager,
any idea?
ERROR Teamcenter.Enterprise.ServerManager.StartServerPoolManager [(null)] - Pool ID to start up not provided; Server Manager will shutdown.
Re: Pool ID to start up not provided
Review the TC_ROOT\net_servermanager\PoolConfiguration.xml. In the <serverManagers> section is the <poolID> tag. Default value is TcPoolA. You may have changed it if you have multiple pool managers installed? Otherwise, I recommend uninstall/reinstall .NET Server Manager.
Evaluating: AW 3.4
Thanks @RandyEllsworth for the reply..
I am using one Server Manager only and in Pool Configuration there is default "TcPoolA" id.
now i have reinstalled the Server manager and its working now.
But dont know why there was problem earlier for starting the service with the same configuration.
