Pool Manager - Information about server xxxx discarded. Process xxxx does not exist
I receive an error after configuring the pool manager. The daemon runs as a process but pools do not publish. I receive the following error:
Any ideas?
3 REPLIES 3
Re: Pool Manager - Information about server xxxx discarded. Process xxxx does not exist
J2EE Pool Manager or .NET Server Manager? Platform (Windows or Linux)? Teamcenter Version? Can you attach the log?
Evaluating: AW 3.4
Hi Randy! Thank you for your quick response. The pool manager is J2EE based(being a novice I'm not quite sure though). Teamcenter is setup on a Linux based system. TC version is 10.1.7.
The log file is attached. Sorry for the mess it looks but I thought because it's going on a public forum, I might as well anonymize the data.
I'm not familiar with running pool manager on Linux. Here are the docs for checking your configuration.
https://docs.plm.automation.siemens.com/tdoc/tc/10.1.7/help#uid:xid1256814:index_server_unix:addingf...
I think it is unusual to use IP addresses instead of computer names (treecache peers). Are you not able to use computer names for some reason (DNS)?
Evaluating: AW 3.4
