Pool Manager settings
hi,
I am getting below error message while starting pool manager,
2017/03/29-11:32:50,422 UTC MLD Log init: com.teamcenter.mld version V11000.2.0.10_20151116.00 (20151116)
log.properties found at D:\Softwares\Siemens\TC11\Tc_Root\pool_manager\confs\config1\log.properties
INFO - NoId - 2017/03/29-11:32:52,142 UTC - AWS-EDGETC01 - Starting Server Pool Mananger.
INFO - NoId - 2017/03/29-11:32:52,181 UTC - AWS-EDGETC01 - Found pool configuration file: D:\Softwares\Siemens\TC11\Tc_
Root\pool_manager\confs\config1\serverPool.properties
INFO - NoId - 2017/03/29-11:32:52,483 UTC - AWS-EDGETC01 - Attempting to establish teamcenter environment ...
INFO - NoId - 2017/03/29-11:32:52,842 UTC - AWS-EDGETC01 - Teamcenter Environment established
INFO - 0 - 2017/03/29-11:32:53,036 UTC - AWS-EDGETC01 - Found tctp configuration file: D:\Softwares\Siemens\TC11\Tc_Roo
t\pool_manager\confs\config1\TctpConfig.xml
INFO - NoId - 2017/03/29-11:32:53,260 UTC - AWS-EDGETC01 - Initialized HealthNotifier on pipeSmiley TongueoolD@3856@AWS-EDGETC01
INFO - NoId - 2017/03/29-11:32:53,261 UTC - AWS-EDGETC01 - Starting HealthNotifier
INFO - NoId - 2017/03/29-11:32:53,362 UTC - AWS-EDGETC01 - Started HealthNotifier
INFO - NoId - 2017/03/29-11:32:53,952 UTC - AWS-EDGETC01 - The Assignment Service has been started at http://AWS-EDGETC
01:8087/PoolD
2017-03-29 17:02:53.956:INFOSmiley Surprisedejs.Server:jetty-8.1.10.v20130312
2017-03-29 17:02:54.118:INFOSmiley Surprisedejs.AbstractConnectorSmiley Frustratedtarted SelectChannelConnector@0.0.0.0:8087
INFO - NoId - 2017/03/29-11:32:55,129 UTC - AWS-EDGETC01 - Mux Address is http://AWS-EDGETC01:8090
INFO - NoId - 2017/03/29-11:32:55,129 UTC - AWS-EDGETC01 - Found TreeCache configuration file: D:\Softwares\Siemens\TC1
1\Tc_Root\pool_manager\confs\config1\TreeCacheTCP.xml
INFO - NoId - 2017/03/29-11:32:55,240 UTC - AWS-EDGETC01 - TreeCache Configuration:
TreeCache Cluster Name=Cluster
TreeCache Mode=TCP
Local Service Port=17801
TreeCache Socket Connect Timeout=2000
TreeCache Peers=localhost[17810]
TreeCache Port Range=1
TreeCache Connection Timeout=15000
TreeCache Merge Min=5000
TreeCache Merge Max=10000
TreeCache Join Timeout=1250
GMS: address is 10.100.1.97:17801
INFO - NoId - 2017/03/29-11:33:03,127 UTC - AWS-EDGETC01 - TreeCache View: [10.100.1.97:17800|2] [10.100.1.97:17800, 10
.100.1.97:17810, 10.100.1.97:17801]
INFO - NoId - 2017/03/29-11:33:03,128 UTC - AWS-EDGETC01 - TreeCache GMS address: 10.100.1.97:17801
INFO - NoId - 2017/03/29-11:33:03,236 UTC - AWS-EDGETC01 - Global pool configuration found.
2017-03-29 17:03:03.237:INFOSmiley Surprisedejs.Server:Graceful shutdown SelectChannelConnector@0.0.0.0:8087
2017-03-29 17:03:03.238:INFOSmiley Surprisedejs.Server:Graceful shutdown o.e.j.s.ServletContextHandler{/PoolD,null}
2017-03-29 17:03:04.260:INFOSmiley Surprisedejsh.ContextHandler:stopped o.e.j.s.ServletContextHandler{/PoolD,null}
Failed to initialize the pool manager
com.teamcenter.jeti.serversubpoolmanager.ConfigurationException: Unrecognized global configuration parameter: "ASSIGNMEN
T_TIMEOUT"
at com.teamcenter.jeti.serversubpoolmanager.ServerPoolManager._setGlobalConfigParam(Unknown Source)
at com.teamcenter.jeti.serversubpoolmanager.ServerPoolManager.loadGlobalPoolConfig(Unknown Source)
at com.teamcenter.jeti.serversubpoolmanager.ServerPoolManager.finishInit(Unknown Source)
at com.teamcenter.jeti.serversubpoolmanager.ServerManager.main(Unknown Source)
Plz do some needfull for me.
