Previous Selected Object
I am writing a script for TcSE and need to access the Previously selected object ...
When I select an object, the value for the global variable $selected is changed to the LOID for that object and the Notebook panel updates to show me the object name, properties,links  ...
If I then select the Links tab, I can see that it is linked to one (defining) object that has two children
Section 1
   ├ Requirement 1
   └ Requirement 2
If I select Requirement 1, the value for the global variable $selected is updated. Is there any way I can access information on the previously selected object?
