Problem renaming UGMASTER object
Hi guys,
I want to rename a UGMASTER in TEAMCENTER Rich Client but I get error like below.
I clicked on Edit Properties on the dataset, check it out, try to rename but this happens.
How can I solve it?
Thanks!
Re: Problem renaming UGMASTER object
This issue may encounter because failed to dataset for XML rendering.
Can you post RAC console log and tcserver*****.syslog ?
Found the RAC log but not the other one.
We need to have tcserver***.syslog to find exact cause of this issue.
Please look at Help->About Teamcenter for syslog location.
You can find it attached.
Not to forget, This is Teamcenter Rapid Start V10.1.3 on a Windows Server 2008 R2 x64
Thank you!
Syslog says as follows
"An invalid object instance tag is being used in conjunction with property %1$s." we never substituted argument 2 : rule_tag
Yes but what does it mean?
This is an NX Part created by NX Integration. Is this normal? How can I fix that?
Can you perform following steps and post the result .
1. Select 'UGMaster' dataset and Click on summary tab.
2. Peform Check-out and modify the 'object name' on summary tab.
3. Peform the check-in .
Thank you very much, that solved it.
How did you understand that this was the problem? The way to solve it I mean?
Or is this a general rule for changing dataset names?
We can modify datasetname in different ways , like using summary tab / Viewer tab ..etc..
But you have some problem when do you perform 'edit properties' , so I still feel this problem releated to some rendering stylesheet.
