Problem with the search
Hello everybody,
Since some weeks, I found a config problem in my Teamcenter (Teamcenter 8.3).
When I do a search and the count of results is bigger than 200! The option to have directly all the results doesn't work.
Do you know the name of options into TC?
Thank you Smiley Wink
PLM Technical IT
Re: Problem with the search
You can try setting the option to a desired value.
WSOM_find_set_search_limit - Set a limit on the number of objects to be loaded after a Find before asking for confirmation - default value(30)
Set this to 1000, to Display up to 1000 objects at a time.
Phani Ryali
