Project stylesheet
Hi everybody,
I need to add a property to a project, defining which type of project is it. For example I want  a property to have the value Plane, Train, or Car and attaching a LOV would be great also.
Here is my problem. I've found in the BMIDE that projet in teamcenter is a POM object named TC_PROJECT and we can add a property to this object. However I need to make it appear on the creation windows of a project. I guess this can be handled by modifying the stylesheet of a TC projet but I can't find it.
Do you have an Idea on how can i solve my problem?
Re: Project stylesheet
You could add you custom property to the CreateInput operation in its Operation Descriptor. You can make it a required field or optional.
Arden Bedell | Teamcenter Wonk | Applied CAx, LLC
Adding properties to OOTB objects is not a best practice. Usually you make your own object then add properties. By making the property mandatory it should show up automagically in the create dialog. Then follow the advice of @ardenb
Evaluating:AW 3.2
I've tried to add it in the operation descriptor but it doesn't appear on the creation page of a project.
I thought I could make it appear by modifying a creation style sheet. Do you know if there is any existing and what is the name because I can't find any
Hello everybody,
Do you have any other idea about my question ?
To give you more detail:
Thank you in advance.
To complete the details I sent you yesterday I have created a children object of Tc_project:
Maybe is there an existing preference or configuration that can allow me to link my new object with the project aplication ?
Best regards.
