Re: Property to fill a dynamic participant
to provide the assigment of Dynamic participants in Stylesheet, provid the following in XmlRenderingStylesheet:
<section titleKey="tc_xrt_AssignedParticipants" title="Projectteam">
             <command commandId="com.teamcenter.rac.assignparticipants" actionKey="assignParticipantsAction" titleKey="tc_xrt_AssignParticipants" title="Assignment of responsibles..."/>
             <property name ="xxxxx" modifiable = "true"/>
       <property name="xxxx" modifiable="true"/>
    </section>
Best Regards
@benjamin1
This may help..
Thank you.
Sorry, Expression should be like this if you want to use the OOTB participants :
<property name ="epm_proposed_reviewers" modifiable = "true"/>
<property name="epm_proposed_responsible_party" modifiable="true"/>
</section>
Thank you a lot @Ri1,
It's what I wanted :)
I have another cuestion, do you kno how restrain the participant for 2 Roles ?
I would like to can assign teamleader or design ingineer role to the participant but not other role.
I saw in the BMIDE this constant:2018-06-28_17h40_57.png
But my value is not working well, maybe syntaw error !! When I put just Teamleader its' working (but just for that role and i would like 2 roles).
Do you have any idea ?
Best regards,
if I understood you right, you want to limit the assignment for Proposed Responsible Party only for Teamcenter group "Teamleader" and "Design Engineer" ? This would lead to a new BMIDE condition on BO Constant "Fnd0ProposedResponsiblePartyAssignableCondition"
Or du you want to assign the your own dynamic participants "Teamleader" and "Design Engineer" in the Stylesheet?
Means create new Participants and new BO Constant, etc.
Hi @Ri1,
iYes, I want to limit the assignment for Proposed Responsible Party only for Teamcenter ROLE "Teamleader" and "Design Engineer".
So I inderstand I need to use the Constant "Fnd0ProposedResponsiblePartyAssignableCondition", but in which properties ?
In the epm_proposed_reviewers I can't see this constant.
I guess your first solution could work, too.
As you mentioned, there is a Syntax error:
Try this pattern for BO Constant "Fnd0ParticipantEligibility"
group::role
I did not find anything for the separator Setting, so I would use "," - like you did ;)
Maybe this works.
Hello  @Ri1,
I'm trying with the syntax group::role
But I have a sub-group, do you know  what is the syntax win sub-group ?
I tried with :
Group::Sub-group::Role1,Role2
Group,Sub-group::Role1,Role2
Group;Sub-group::Role1,Role2
Group::Role1,Role2
But it's not working.
Thank you in advance for your help.
Regards.
Have you tried the dot naming scheme? SubGroup.Group::Role
Thank you @RandyEllsworth,
Now it's better, but I have a problem with the second role.
It's working well with subgroup.group::role
but it's not working with subgroup.group::role1,role2
I tried with:
subgroup.group::role1.role2
subgroup.group::role1;role2
subgroup.group::role1::role2
subgroup.group::role1, subgroup.group::role2
But none of these syntax works.
Regards.
