Pseudo Folder (release_status)
is it possible that a PseudoFolder only shows ItemRevision with a specific release_status respectively hides ItemRevisions?
Thanks!
Best regards,
Thomas
4 REPLIES 4
Re: Pseudo Folder (release_status)
Pseudo folder = relation type. The pseudo folder is just a nice way to organize and display objects related to revision. It doesn't have anything to do with the status applied to those objects. Can you explain your requirement a bit more please? Why do you need to hide the ones with a red dot? Maybe there is another way to do whatever you are trying to accomplish?
Jamie
Jamie Griffis | PLM Solution Architect | Engineering USA
Hi Jamie,
thank´s for you reply!
These ItemRevisions having that red dot means that they are not valid anymore.
So it just would be a clearer representation of that content.
Another idea to achieve that is adjusting the summary-stylesheet. I think that could be possible and at least the summary is showing only the valid (green dot) ItemRevisions.
Best regards,
Thomas
@TomK76 - Are the ones with a red dot a different status? You could restrict the display of objects per status to different groups. An example would be that Engineering can see everything but non-Engineering groups would only see specific Item Revs or dataset types with a specific status. Maybe that will also help achieve what you are trying to do?
Jamie
Hi Jamie,
yes the one with the red dots have a different status.
What you write is exactly what I would like to achieve :-)
Could you give me a hint on how you would do that? Is this something in the ACL?
Best regards,
Thomas
