Purge Revision
Hi everybody,
I would make a purge on all revision in my Teamcenter database. Do you know if a CLI exist?
Thankx
PLM Technical IT
Re: Purge Revision
Hi ,
Check utilities reference guide for command "purge_baselined_item_revisions".
It suppouse to server your purpose for purging revisions in database. if not, then I would have written a custom ITK utility to do so.
Harshal Vispute
Technical Consultant @ Atos , Germany
ITK , T4S Interface
Re: Purge Revision
Thank you.
I will try this during Christmas holiday.
Best Regards
PLM Technical IT
