Query Builder: Assembly to child Component (Precise Structure)
In query builder I try to find element revision in assembly. If I use default query from helper: Assembly to child Component (Imprecise Structure) - It work's and finds some Items in my assembly. But if I use default query from helper: Assembly to child Component (Precise Structure) - It doesn't work and not finds ItemRevision. Help me, please.
Re: Query Builder: Assembly to child Component (Precise Structure)
Good afternoon, for me this query works.
Check that you have switched the assembly to Precise:
Do not forget to save the changes:
Note that this sample query looks for an item revision by the Name attribute
Also a request to you, if in the previous topics the answers solve your problem, mark in the topic that you found a solution
I found I had to edit the query from the helper by using custom revision rather than OOTB ItemRevision:
structure_revisions.PSOccurrence<-parent_bvr.IE4_ItemRevision:child_item.process_stage_list
Richard
www.prospectplm.co.uk
Richard Bennett
PLM Consultant
www.ProspectPLM.co.uk
