Query builder: Find datasets where release status differs from ItemRevision
experiencing a bug that some datasets are not revised correctly regarding their status I would like to find all datasets where release status (status: 62) is not equal to the release status of the ItemRevision (status: 90).
Has anyone an idea what attribute has to be used?
I tried to use the revisionAnchor and rev_chain_anchor as well as the itemtag but it did not deliver the desired result.
Any help is highly appreciated.
Best regards
Julian
3 REPLIES 3
Re: Query builder: Find datasets where release status differs from ItemRevision
alright, I have found a solution. Maybe it will come in handy for someone else:
In the Query builder select base class: Item Revision
To look for item revisions with a specific release status:
  • release_status_list.name
To look for datasets with a specific release status simply add:
  • dataset.IMAN_manifestation.release_status_list.name
> the IMAN_manifestation was in my case the relation how item revisions and datasets are linked.
> Make sure "all attributes" and "real names" are selected in "preferences".
kr
Julian
I know this is years later, but I desperately need to get this to work. Can anyone clearify this query, maybe a screen shot of TC Query Builder search criteria pane. I need to search on Released Item Revisions that contain un-released PDF's
the screenshot below shows the selected "Search Class" = Item Revision
In the "Search Criteria" look for IMAN_manifestation. Double Click and select "dataset".
after that look for "release_status_list" and select below the "name".
Hope that helps.
br
Jul1an
