Query for item revision with status from imprecise BOM in Workflow
Hello all,
I am attempting to run validations through a workflow on a structure of a machining operation. One such validation is that if an MFG Doc item is present in the BOM, then check if there is a latest released revision. I have the existence validation working by using the structure_revisions.PSOccurrence<-parent_bvr.Item:child_item.object_type = MFG_DOC. I can't for the life of me get any doc item revision and its release status name though. I have the BOMView Revision as a target of my workflow.
Any help would be greatly appreciated and I'm sure very interesting!
