Query results without Dataset versions
Siemens Creator
I set the preference QRY_dataset_display_option=2 that means the Option "Latest Dataset Versions" is active.
Then I use the Query "Dataset..." with Name and Type and get the awaited result. Only one Dataset version.
Now I use the Query "General.." with the same Name and Type but I get all Datasetversion in the Search Result.
I expected the same result as with search "Dataset..." .
How can I configure that?
Maik
8 REPLIES 8
Re: Query results without Dataset versions
Initially I thought QRY_dataset_display_option=2 would control the 'Latest Dataset Versions' option but after testing it appears it doesnt.  Set the option below and it should work.
Richard Bennett
PLM Consultant
www.ProspectPLM.co.uk
Siemens Creator
Hi Richard,
I already set this option, but it works not with Query "General..."
Siemens Creator
The same settings with Query "Dataset..."
Our systems are working differently.  If I enable the 'Latest Dataset Version' option the General search only returns latest.  If I disable (uncheck) this option, the General search returns all versions.
Maybe its a bug with your patch of TC?  We are on TC 11.2.2.1.
Richard Bennett
PLM Consultant
Siemens Creator
My version is TC11.4.0.6
Try setting TC_QRY_display_latest_dataset_only = 1 (default is 0 - displays all versions).
Evaluating: AW 3.4
Siemens Creator
Thanks Randy for your response.
This preference was already set to 1.
Siemens Creator
I have created a GTAC ticket. It seems to be an problem in this version.
Fixed in TC11.5 and TC12.
