QueryBuilder Find DirectModel without Namend References (ref_list)
Hi Guys,
i looking for a solution.
My problem:
There are broken DirectModel Datasets. There is no JT File in Named References.
So I tried in QueryBuilder:
Dataset:IMAN_Rendering.object_type -> DirectModel AND
Dataset:IMAN_Rendering.ImanFile:ref_list -> IS_NULL
Dataset:IMAN_Rendering.ImanFile:ref_list.file_name -> != *.jt
Dataset:IMAN_Rendering.ImanFile:ref_list -> != *.jt
Have you an idea.
Regards Nithi
3 REPLIES 3
Re: QueryBuilder Find DirectModel without Namend References (ref_list)
maybe the dataset_cleanup utility can help you to find these datasets and fix them.
That is not what I expect. In my case I need the IRs to resend them to the Dispatcher.
The screenshot is what I use to look for missing named references in the RAC. It allows you to select any object type from the drop down in the query. I suppose you can set a default value to be DirectModel but I prefer to the flexibility to search any type as needed.
Jamie Griffis
