QuerySearch
Hallo,
I want to create a QuerySearch, which is seacrhing the examples (with link) like below.
I have built a QuerySearch, but it´s not works ("No object found").
Here is my QuerySearch:
any Idea?
3 REPLIES 3
Re: QuerySearch
@Locash - from what I understand from the picture, you're going to need to create the query to find the "linked" object via the relationship that is attaching it to the other. What is the relationship you are currently using?
Jamie Griffis | PLM Solution Architect | Engineering USA
Re: QuerySearch
Lets break your query down.
owning_group.name
This is the name of the owning group of the object you are searching for.
object_type
The type of object you are looking for.  In order for this to work in your query, the search class would have to be set to Dataset I think.
object_name
Searches on the name of the object
Dataset:ref_list.object_name
Searches for the name of the file under a dataset.
You currently have a default value for your last argument of CATPart.  I would have thought the name of the file would be 'PANEL_XXXX".
Rich
Richard Bennett
PLM Consultant
www.ProspectPLM.co.uk
Re: QuerySearch
Hallo,
Relation is BMW_DS_FORM_link
Any idea?
