Question about Part, Commercial Part (Vendor Management) and Design
Ciao a tutti!   Hallo everybody!
I've a little question about OOTB function and best practices to use Part and Commercial Part.
Can we have a dataset directly inside Part Item?
Can we use a "mixed mode", with some Dataset on Design Item, some on Part and some on Commercial Part?
I hope I have been exhaustive
Thank you
Re: Question about Part, Commercial Part (Vendor Management) and Design
A Commercial Part is related to 1 or more Vendor Parts.
Ofcourse you can assign all kind of Datasets to any object, but it doesn't make sence to assign a CAD Dataset to the PartItem. In your example you use Structure Manager. There you can combine all Object Types.
First you need to be sure how your datamodel looks like. (ObjectTypes, Relations etc)
You can check the following blog for more info about Part and Design Objects.
http://community.plm.automation.siemens.com/t5/Teamcenter-Blog/Defining-the-Part-Bill-of-Materials/b...
