Question about Preferences
Hello Team,
While exploring the utility reference I found these
-mode=delete will delete the defination of the preference
and
-mode=remove is removing the instance of preference.
Please explain the difference between an Instance and defination of the Preference in Teamcenter.
Sandeep
Re: Question about Preferences
In order to delete the definition you have to first remove all the instances.
Evaluating: AW 3.4
