Questions about MPP and TC Vis functionality
Are these capabilities possible within TC?
MPP Configuration - linking structures (EBOM to MBOM) should show relation in Attachments tab and Impact Analysis tab
MPP Configuration (Process Gantt) - enable activities to show in Process Gantt module
Visualization – can the exploded views generated by TC Vis Markup during assembly be displayed outside of TC by the TC Vis Pro or TC Vis Mockup application
Re: Questions about MPP and TC Vis functionality
So far my research has lead me to beleive that the gantt chart is not an available option within TC. All documentation is pointing over towards plant sim.
