Redundant License servers
Siemens Creator
How to get License servers name which are currently pointed by Corporate server in triad License server configuration?
Re: Redundant License servers
You can find that in TC_DATA\tc_profilevars.bat file
search for the SPLM_LICENSE_SERVER
or else
open a TC command prompt on the 2 tier client and enter    “set SPLM”    and see what the variable is set for SPLM_LICENSE_SERVER!
Rafa
Siemens Creator
Thanks for replying, But I have added 3 servers in TC_DATA\tc_profilevars.bat so I specifically wanted to know that current session is pointing to which server out of that 3.
the Syntax for tc_profilevars.bat as follow:
set SPLM_LICENSE_SERVER=28000@Server1,28000@Server2,28000@Server3
As seperator you must use a comma ,
In your license file use this syntax:
SERVER Server1 COMPOSITE=xxxxx 28000 PRIMARY_IS_MASTER
SERVER Server2 COMPOSITE=xxxxx 28000
SERVER Server3 COMPOSITE=xxxxx 28000
The first license server ist the Master. (PRIMARY_IS_MASTER)
This is the server which will connect first from the NX/TC
Michael
Use lmtools to determine which server is currently active. Launch lmtools, Server Status (tab), click Perform Status Enquiry. Review the license server status in the window.
Evaluating: AW 3.4
