Reference to ps_children attribute from Query Builder
I have some issue when I tried to get reference to ps_children attribute my ItemRevision element from Query Builder. I don't saw this.
If I rigth understand - ps_children is Runtime attribute and this doesn't display in Query Builder. How can I get access to the elements by this reference?
6 REPLIES 6
Re: Reference to ps_children attribute from Query Builder
Good afternoon, if the ps_children attribute is runtime, you can not use it in Query Builder
I do not know what task you need to solve, but if you work with occurrences I think you need to use PSOccurrence
Example:
It works!
But in the Query Builder I don't see element parent_bvr. Why? I typed query row in hand mode.
In order to execute this query step by step and you better understand, do the following:
1)
2)
2.png3)
4) A step-by-step guide will be available in your language:
Thank you
It solved my issue
Where can I read more about references between objects in foundation model?
For example, I have some structure in Structure Manager, how can I reference to this structure?
