Referenced ItemRevision in Teamcenter navigator for NX
ItemRevType1 has ItemRevType2 attached with IMAN_reference relation. ItemRevType2 has UGMASTER dataset attached. In Tc Navigator of NX, only ItemRevType1 is visible.
Is there any setting with which ItemRevType2 can be seen under ItemRevType1 in Teamcenter Navigator ?
Re: Referenced ItemRevision in Teamcenter navigator for NX
Siemens Creator
          Can you try the following  steps and see if it is working :). As myself did not test this solution.
  1. Choose File tab→UtilitiesCustomer Defaults.
  2. In the Customer Defaults dialog box, selecte Teamcenter Integration for NX.
  3. Click the Teamcenter Navigator tab.
  4. Select the Show Activity Data check box.
Thanks & Regards,
Nagi
 Hi Nagi, @5prye8
thanks for your reply. This did not work.
