Releasing a NC Machining Revision
I wanted to release and NX CAM template in Teamcenter, to prevent modifications, and saw there was no release option.  I presume because there was no workflow created to release that Item type?
-Dave
Re: Releasing a NC Machining Revision
You probably have "CR_allow_alternate_procedures" set to "none". You can change that to "any" or "Assigned". For Assigned you'll also want to declare which workflow should be available...
TC_<object_type>_release_procedure. The <object_type> should be the Item Revision type containing the NX CAM template you want to release. A good candidate is "TCM Released".
Thanks @RandyEllsworth
-Dave
