Removing old template from TC
I was able to add updated template to the Team center. I did not see any option to delete the old template.  Could you let me know how to delete the old one
Re: Removing old template from TC
Any help on this would be appreciated!
Are you talking about Solid edge templates?
If so, how did you updated your existing templates?
Rafa
I could not update existing one in TC. If I updates, it creates new item. then I imported updated one like R5 to R6. which created 2 copies old and new. I wanted to remove old one. I am not sure where it was located. Now I found the location which was in the Home folder. I removed old one.  Thank you all for support and help
