Reset Naming Rule Number Generator
We are making a roll back and would like to manually reset the intial value for the naming rules ( 'NNNNN' ) to a different number.
Changing the InitialValue in BMIDE did not do the trick. Is there something we are missing?
Thanks in advance
Betreff: Reset Naming Rule Number Generator
Try to change the Rule 'NNNNN' to 'nnnnn'. This should reset the value.
Michael
Teamcenter UA | NX CAD
I meant to write 'nnnn'. Sorry for confusion.
No matter how the rule pattern looks like. The trick is to change the pattern in a way to keep the rule and reset the counter. Therefore, try to change any 'N' to 'n' or 'A' to 'a' or 'X' to 'x'. This is just an example...
Michael
Thank you for the explanation. I will get back to you after testing :) Kudos!
You can build a query to get the naming rule counters, see the XML code below.
<?xml version="1.0" encoding="utf-8"?>
<!-- GENERATED BY: PLM XML SDK 7.0.4.411 -->
<plmxml_bus:PLMXMLBusinessTypes xmlns="http://www.plmxml.org/Schemas/PLMXMLSchema"
 xmlns:plmxml_bus="http://www.plmxml.org/Schemas/PLMXMLBusinessSchema"
 language="en-us" time="16:15:31" schemaVersion="6" author="Teamcenter V10000.1.0.70_20161101.00" date="2018-04-05" languages="en-us fr-fr de-de it-it es-es pt-br">
<plmxml_bus:SavedQueryDef id="id1" name="Admin - Find nameing rule counters" nameRef="#id2" descriptionTextRef="#id3" queryFlag="0" queryClass="NameCounter">
<Description>Search for naming rule counters</Description>
<ApplicationRef application="Teamcenter" label="RyBABjYqRr3t9B" version="RyBABjYqRr3t9B"></ApplicationRef>
<plmxml_bus:QueryClause id="id4" stringValue="SELECT qid FROM NameCounter WHERE &quot;counter_name&quot; = &quot;${counter_name = }&quot;"></plmxml_bus:QueryClause></plmxml_bus:SavedQueryDef>
<plmxml_bus:Text id="id2" primary="en-us"></plmxml_bus:Text>
<plmxml_bus:Text id="id3" primary="en-us"></plmxml_bus:Text></plmxml_bus:PLMXMLBusinessTypes>
You will have to import the query with query builder to use it.
Deleting the counter object is the same as resetting it, since there is no ability to reset it.
