Reset property value on Revising
Is there a way to reset custom property (on Item revision master form) to blank on Revising operation. Basically I dont want poperty value to be carried forward Ex: from rev0 to rev1
Naveen
TC9.1
Re: Reset property value on Revising
Hello
We have written an Extension on the Revise action to reset the values to null. It works fine. There are many Sample ITKs in GTAC, you can refer them.
But I always wondered if there was Deep Copy rule to control copying of objects then why not for attributes as well. If there is an OOTB solution, i would happily take it.
