Restrict naming rule usage
Has any of you already had the need to retire naming rules?
The existing items should still be usable, but new items should not be allowed to be created with the retired naming rules.
I imagine that the conditions could be used for this, but I haven't had time to check the BMIDE by now.
Thanks in advance for your experience ;)
Employees of the customers, together we are strong ;)
16 REPLIES 16
Re: Restrict naming rule usage
You want to completely not use that naming rule any more? You should be able to just remove it from your item type in BMIDE without issues. The existing items in TC will not be affected but no more new numbers will be available. It's been a while since I needed to do this, so I'd suggest testing it out and make sure revisions still function (but I think they will work fine).
I've used conditions to restrict naming rules to specific groups. So instead of removing it completely, you could set it to be available for just DBA for example.
Jamie
Jamie Griffis | PLM Solution Architect | Engineering USA
Thanks for your suggestions, I will post back with the results.
Hello @Jamie_Griffis,
do you or anyone else have an example of the condition that should be used to restrict the naming rule application to a specific group?
I tried to create a condition, but it failed to work out as expected.
Thanks in advance.
@Stefan_Pendl - Before I attempt to show you what I've done before (and possibly confuse the situation), how many groups are able to create this item? How many are restricted to each naming rule? Are there only 2 naming rules or more?
Jamie
@Jamie_Griffis,
initially there will be only MENCTool created by two groups and one naming rule for each group.
I think that I had the condition wrong, so I would just need a screen-shot of that.
Usually the condition isTrue() is used for our naming rules, but I need to refine them now.
@Stefan_Pendl - Here is a quick example. Create 2 conditions, one for each group type. Mine is dba or not dba, your's would be group "a" or group "b".
Condition example. You will create a 2 custom user session conditions (one for each group/naming rule), name the condition something that makes sense to you. Your group will be inside the quotes. Could be like "Engineering.SiteA" (I'm just making up examples because I'm not familiar with your Org.)
Add the 2 naming rules to the item using the 2 conditions:cond4.png
Hopefully that helps. Let me know if it works or not.
Jamie
Sorry, but I still seem to miss something, since I don't get a rule selector when creating the item.
Conditions:00_condition_one.PNGCondition One
01_condition_two.PNGCondition Two
I also tried with custom input parameters, but no chance.
Naming Rules:02_naming_rule_one.PNGNaming Rule One
03_naming_rule_two.PNGNaming Rule Two
MENCTool:04_item_definition.PNGItem definition
Display in New Item dialog:05_new_item_one.PNGNew Item One
06_new_item_two.PNGNew Item Two
What could be causing this, if the settings are all correct?
Thanks in advance for any pointers in the right direction.
If I use IsTrue() as the condition for one rule, I get the patterns of that one rule, but then I cannot specify different rules :smileyfrustrated:07_use_condition_istrue.PNGUse Condition IsTrue()So things seem to be updated as expected.
It will take me a bit to get back into my system to figure out how I got it working. I'll get back to you.
