Re: Restrict naming rule usage
Mine works... can we take this offline over email to work it thru and just post the results here? I'll send you my personal email.
Jamie
Jamie Griffis | Teamcenter Architect | Applied CAx, LLC
Sure, lets do the hard stuff offline and report the solution here.
BTW, which Tc release are you working with, mine is Tc 10.1.7?
Employees of the customers, together we are strong ;)
Did you folks fix this? What was the answer?
Evaluating: AW 3.4
@RandyEllsworth - it works for me, and I'm using it currently. Stefan hasn't got it working yet or not that I've heard back. We are on different versions of TC and I don't any problem in TC11, seems to be a problem in TC10. I don't have anywhere with TC10.x installed to test.
Jamie
Tc10.1.7 appears to honor the same as Tc11.2.x. Make sure to check "Override" to prevent the condition checking the parent instead of using the isTrue (default) condition.
https://docs.plm.automation.siemens.com/tdoc/tc/10.1.7/help#uid:xid1256815:index_plm00071:id1637945:...
Evaluating: AW 3.4
Sorry had to switch to more important work :(
Overwrite is only available for isTrue() conditions, so I removed the naming rule setting from the resource item to make it display the one for METool.
Others have used equal and not equal to the same group, but I need one or the other group, which seems to be the culprit.
Will report back with my findings.
So I have found time to make up my mind once more about this subject and found a solution.
Since many of our users are members of multiple groups, the simple group_name check doesn't work, instead one needs to use the function "fnd0getGroupName()".
Conditions:Condition_01.PNGCondition Group HAI
Condition_02.PNGCondition Group HTM
Naming rules:NamingRule_01.PNGNaming Rule HAI
NamingRule_02.PNGNaming Rule HTM
Proposals when creating an item:NameProposal_01.PNGName Proposal HAI
NameProposal_02.PNGName Proposal HTM
Hope this helps.
