Restriction on assigning an item level on the projects - TC11.4
Hi Experts,
Is there any way to assign only item revision to projects while "File->new->item creation"
When I assign project,while item creation both item and item revision sits on to the project, i need only item revision to go to the project.
Rafa
Re: Restriction on assigning an item level on the projects - TC11.4
Yes, you have to make that change in BMIDE.
Jamie Griffis | Teamcenter Architect | Applied CAx, LLC
Jamie,
Could you please tell me what would be that change?
Rafa
