Do you mean
Reply
Restriction on assigning an item revision to a project
hi,
I want to set a restriction such that an item revision of a particular custom item should be assigned to a project only once.  Any other item revision instance of that  custom item should not be assigned to that project. Is that possible?
Thanks and Regards,
Sanket Pusalkar
