Retrieving older data from database
Hi guys,
Suppse I've created an Item 1st of May 2017. Today it is 17th of May.
Is it possible to go back and get the data from 10th of May just for that Item?
Cem
6 REPLIES 6
Re: Retrieving older data from database
You can query and retrieve data for items based on dates (dates such as: created data, last modified date, released date etc).
Let us know if I misunderstood your question.
Harish
I wanted to mean something like that.
We have an Item called 000055.
I want to return to the state of the same item 3 days ago.
Cem ALPAY
Üçgen Yazılım Ltd. Şti.
--Mobil cihazımdan gönderildi--
Is it on Item or ItemRevision ? If its ItemRevsion, you can retrive the old state using "Sequence" ( Of course, based on your configuration for sequences - like whether to keep it, no of sequences, etc )
How can I get to the sequences??
Cem ALPAY
Using All Sequences or Specific Sequence queries defined under System Defined Searches.
You will be having data in datasets which are on Item Revisions, You can track the changes in these datasets by means of Version. Sequence will not be having any real time changes its just mechanism to know how many time your revision has been checked out even you havent modified anything in that.
