Return objects from sub process
When running a sub process in a workflow I would like to have the targets from the sub process set as targets to the main workflow before everything continues. Anyone who knows if this is possible somehow without making a custom handler.
We are running TC 10.1.7.
Björn Andersson
Solution Architect
PLM @ Nibe AB
Re: Return objects from sub process
I assume that a target of your main process becomes a target of your sub-process? And then you gather new targets into the sub-process?
1 method could be to relate your new targets of the sub-process to the target of your main process. Then when the main process resumes is gathers the related targets using epm-attach-related-objects.
You could use OOTB relations, or create a custom form that has custom relations etc etc.
Richard
www.prospectplm.co.uk
Thanks for the quick answer.
This solution will solve my problem.
Björn Andersson
Solution Architect
PLM @ Nibe AB
