Revise Multiple Item Revisions
Builder
Builder
Is there a way to revise multiple Item Revisions ?
Santosh
12 REPLIES 12
Re: Revise Multiple Item Revisions
Using RAC UI?
Builder
Builder
Yes Using RAC UI or any utility. I have around 500 item revisions which needs to be revised.
Santosh
have you got IPS?  you could create new revisions with IPS.  Would be a bit of a pain if you have datasets that need copying forward though!
Richard
Richard Bennett
PLM Consultant
www.ProspectPLM.co.uk
Builder
Builder
Richard,
Yes I have IPS. It will not solve my purpose.
Like you said the dataset will not be propagated to next revision. I have datasets which needs to be propagated to revised revision.
Santosh
I just checked the IPS documentation for revising:
"In Teamcenter Engineering V9+ a Deep Copy will also be performed on any new Items or Revisions to perform any Deep Copy Rules that may be set."
So, according to the documentation it will work.
Richard
www.prospectplm.co.uk
Richard Bennett
PLM Consultant
I just tested using items mode using the following options and it created a new revision and copied forward the correct datasets:
CREATE ITEMS = OFF
UPDATE ITEMS = ON
CREATE REVS = ON
UPDATE REVS = ON
UPDATE LATEST REV = ON
UPDATE REV ATTACHMENTS = ON
DATE FORMAT = %d/%m/%Y %H:%M:%S
SET BYPASS = ON
!~ItemID~NewRevID
2011002836~
Note: Leave NewRevID blank
Richard Bennett
PLM Consultant
Builder
Builder
WIll try it out. Out of curoisity. Have you tried the same with TCXML ?
Santosh
Yes, either with PLMXML or TCXML at some point in time I have. Problem is TCXML or PLMXML create revisions, they don't revise. So yes, they will create the revisions, but they won't have any of the datasets of the previous revision.
Richard Bennett
PLM Consultant
Prospect PLM Ltd
Richard Bennett
PLM Consultant
Builder
Builder
Will this also work with ps_upload.exe ?
Santosh
