02-22-2018 06:42 AM
Can we have a revision ID naming rule that starts at A1.. A9, B1..B9, C1..C9 etc upto Z9?
I have tried to configure a revision naming rule and a naming rule but unable to do so. Am i Missing anything?
02-22-2018 10:14 AM
Did you tried to create a naming rule for the RevID (not a revision naming rule)?
Pattern: An
Generate counters: true
Initial Value: A1
Maximum Value: Z9
This pattern should count the right numbers first. After number nine the letter should switch to B.
Map this rule to the revision_id attribute on the revision.
