Revision Rule
Hi, I got confused. My friends told me that precise structure does not read revision rule, but imprecise  structure read revision rule. Is this correct?
I could not find this information in pdf. Could you give some advises?
Re: Revision Rule
Precise assemblies are fixed structures of specific item revisions. A precise assembly has links (occurrences) to specific item revisions of its components. When a component is modified to a new revision, you manually edit the assembly to remove the old revision of the component and replace it with the new.
Imprecise assemblies are dynamic and refer to items, not specific item revisions, as their components. Teamcenter applies a revision rule to determine the revision of each component in the product structure when it is loaded.
Re: Revision Rule
However, it is possible to treat precise structure as imprecist by applying revision rule that contains configuration entries other than "precise" entry.
In other words, inside Teamcenter, precise structure behaves as precise structure only if the applied revision rule contains only "precise" entry.
Thanks and Regards
Yogesh Fegade
