Revision naming rule applied except on the first revision
Hi all,
I am trying to reproduce this scheme of revision for a client : OI A B C D E F G H J K L M N P R T U V W Y
Basically, I need to exclude I O Q S X Z, which is easy enough. But, the first revision needs to be OI. The only way I can think is to use a condition on the revision naming rule so that it only applies on the 2nd revision and onward, but I want to know if you have any other ideas, or know which condition I could use.
