Revision property; manifestations
I would like to show this property in the columns of the structure manager. Is that possible? What is the name of the property to look for it? Thanks
Re: Revision property; manifestations
Hi @Javiduc,
When drawings are exported as a PDF then it gets added as dataset under item revision with relation 'Manifestations'.
What is your purpose? As in structure manager you can see only item revisions (BOM Line), no datasets.
Ganesh Kadole, QA Analyst (PLM), SQS
Testing: NX 11 | NX 12 | TCIN
TC 11.2 | TC Vis 11.3 | AWC 3.2
I would like to see the name of the dataset like I can see it in properties of the item revision.
The purpose is to quickly know what item revisions doesnt have a pdf dataset so we still need to print the drawing.
