Running events on Teamcenter Server
Dear all,
We have developed Teamcenter integrations with 2 CAD softwares using SOA API. I got following requirement for the integration product:
1. An event should run continuously on server for ex. to monitor check-out operations on parts
2. If a part is checked-out (from any client), the checked-out object Uid should be added to a list
3. If any user (from any client) loads any of the parts from the list, he should get a notification/warning (that the part is checked-out by other user)
Check-out is just an example. Event could be used for any other operations.
Any suggestions how this could be implemented ?
Thanks in advance!!
Re: Running events on Teamcenter Server
You could open the part/assy in Structure Manager with the checked-out column displayed and expand all to see if anything is checked out then send to CAD. However, it won't raise a warning by itself. Maybe you can do something similar using SOA?
Evaluating: AW 3.4
Thanks @RandyEllsworth for your response. I will check if this property could be useful in our use case.
I also found "ModelEventListener.SharedObjectChange()" API which notifies a user on one client if an object is modified by a service call from other clients. But I have not tested this yet. I will update soon.
Hello everyone,
I have figured out the first 2 steps. Now I need help in 3rd step
Step 1. Using subcription manager, subscribe to TC-Objects for checkout-events
Step 2. Subscription manager will call a customized handler (instead of default SMTP_notify handler)
Step 3: Sending notification on a client machine:I need your opinions here.
On client machine, a CAD Session is running and it is connected to a TcServer session using SOA Services. The CAD user needs to be notified that a part loaded by him (from Tc) has been checked out by other user.
Any suggestions ?
