Re: SOA API - How can I add a SignOff User to the Workflow?
Siemens Legend Siemens Legend
Siemens Legend
If you are looking for details of the currently logged in user then the SessionService has getGroupMembership and getSessionGroupMember calls.
If you have a user and group name then the most straightforward way is probably to create a query that returns GroupMember objects, and execute it from SOA.
Ok, perfect! Thanks for the quick response.
Hello MF3,
Can you please share how did you get the signoffMember to assign to CreateSignOff.signoffMember ?
I have tried get_fnd0Performer() and get_fnd0Assignee() from EPMTask. But none of them is working.
Call to
wfService.addSignoffs(new CreateSignoffs[]{createSignoff});   --  says "The signoff member is invalid."
Appriciate your help.
Mabye this helps a little bit.
// load group member by fixed uid for example. Group member is not a user!
GroupMember gm = (GroupMember) loadObject(uid);
// load the task
EPMTask epmTask = (EPMTask) loadObject(uid);
// load addtional fields for the task
loadData(epmTask, "signoff_profiles");
final ModelObject[] signoff_profiles = epmTask.get_signoff_profiles();
CreateSignoffs createSignoff = new CreateSignoffs();
createSignoff.task = epmTask;
createSignoff.signoffInfo = new CreateSignoffInfo[signoff_profiles.length];
for (int idx = 0; idx < signoff_profiles.length; idx++) {
	ModelObject profile = signoff_profiles[idx];
	createSignoff.signoffInfo[idx] = new CreateSignoffInfo();
	createSignoff.signoffInfo[idx].originType = "SOA_EPM_SIGNOFF_ORIGIN_PROFILE";
	createSignoff.signoffInfo[idx].origin = profile;
	createSignoff.signoffInfo[idx].signoffAction = "SOA_EPM_Review";
    // set the group member
	createSignoff.signoffInfo[idx].signoffMember = gm;
// add signoff
final ServiceData serviceData = wfService.addSignoffs(new CreateSignoffs[] { createSignoff });
