cancel
SOA .NET using Revision Rule
I need an example of using RevisionRule in soa .net
I have to find the correct RevisionRule (by name) and get the Item revision accordingly.
Ohad.
Re: SOA .NET using Revision Rule
I guess you already know the method GetRevisionRules, don't you?
Do you want to apply the rev rule to BOMView in SOA?
xtof
I need to apply the RR on specific Item - not on BOM
I used GetRevisionRules to find the proper RR.
Then i found the method GetConfiguredItemRevision that should retrive the ItemRev according the RR and Item - Thanks xtof.
Ohad.
