SOA: What is TextInfo from API GetTCSessionInfo()
Any idea what information does the array TextInfo from GetTCSessionInfoResponse contain ?
This array is always null in my case.
Re: SOA: What is TextInfo from API GetTCSessionInfo()
Good afternoon, I do not know what is in the array TextInfo, but you can use extraInfo:
1)
private static void getTCSessionInfo() throws ServiceException
       //com.teamcenter.services.strong.core.SessionService
        SessionService sessionService = SessionService.getService(connection);
        GetTCSessionInfoResponse res =  sessionService.getTCSessionInfo();
        System.out.println(res.extraInfo);
2)
        tcSyslog = (String) res.extraInfo.get("syslogFile");
Hello @ArthurRM, thanks for your reply.
Yes I am already using ExtraInfo array to get infos like syslogFile. I was just curious about TextInfos.
