SSL / HTTPS configuration for FMS
Hello Experts,
a happy new year to all.
I have done SSL/HTTPS configuration for FMS and I could start FSC service successfully. But I get following error. Error log of startfcc.bat is also attached.
Captured SSLHandshakeException. Cause: SSL peer shut down incorrectly:com.teamcenter.net.proxy.http.ProxiedHttpClient.executeMethodInternal(ProxiedHttpClient.java:566)
Any idea what's wrong ?
11 REPLIES 11
Re: SSL / HTTPS configuration for FMS
The message "Captured SSLHandshakeException. Cause: SSL peer shut down" tells me that the client isn't configured for SSL.
What have you done on the client side to implement SSL for Teamcenter?
Larry Carpenter, P.E.
Here's what I do to implement SSL with Teamcenter. Maybe it'll help you figure out what you left out.
Hi @LarryCarpenter thanks for your reply.
On client side I have updated fcc.xml with the new (HTTPS) FMS URL.
Thanks for sharing the document. I will go through it and let you know further updates.
hello
hello @wangrui I have used only the Siemens Teamcenter documentation. Please find below the link to the documentation.
https://docs.plm.automation.siemens.com/tdoc/tc/11.5/help/#uid:xid1256816:index_plm00102:id270446:xi...
However, I haven't got complete success yet.
@LarryCarpenter: Thanks again, I have gone through your documentation. The only thing that was missing in my configuration was updating the preferences (Fms_Bootstrap_Urls, Default_Transient_Server).
Even after updating the preferences I get the same error.
Sorry to hear that. Sounds like you may need to call GTAC to get to the bottom of it.
Hi Amol,
Based on error SSLHandshake error. i suspect the following.
The certificate used for encryption is not imported where you are starting this batch file (cacerts file available in java/jre/lib/security which used for Teamcenter FMS configuration need to be updated with the certificate, be it self signed or the one purchased)
Phani
Hi Phani,
thanks for your response. I added the certificate to cacerts file in JRE security, but it still not working.
As Larry said, I will raise the issue in GTAC.
