SSO configuration with authentication service other than LDAP
Hello Team,
I am trying to configure SSO, where I want to use our Internal authentication service for the Identity Service.
When I am looking at Siemens documentation for SSO, Siemens has provided the procedure for the only LDAP.
Can someone guide how to achieve SSO with another authentication service, if it requires customization from where I need to start?
Ganesh
Re: SSO configuration with authentication service other than LDAP
I have not done this, but following tips should help:
The Custom (Java-) Class calling the Identity provider can be provided as a context parameter while configuring Identity Service. Context parameter name:"identityProvider".  Its default value is 'com.teamcenter.ss.identity.spi.LDAPIdentityProvider'.
The default Jar file (teamcenter_sso_ldapidprovider.jar) is available at  %IdentityServiceStagingLocation%\webapp_root\WEB-INF\lib. So you can copy your custom Jar at the same location.
