SSO using kerberos authentication
Does anybody have idea or, if possible, a stepwise documentation for SSO with kerberos authentication ?
In particular, I did not understand what settings should be done for TCCS and what the Krb5.ini file look like.
I tried it with help of TC-doc, but I get error: "Configured behind gateway but no UserID provided. See Administrator”.
Have also logged to GTAC, but waiting for response.
Thanks in advance!
8 REPLIES 8
Re: SSO using kerberos authentication
See attached from PLM World 2015 and hope it helps...!
  @hungnguyen : thanks a lot for the doc. I will try this and share the result!
Teamcenter - SSO Login Error
The login attempt failed: either the user ID or the password is invalid.   Click on Login to try again.
Configured as document provided,we are not able to login webclient.
I recommend you to give GTAC a call so they can assist you to verify about that.
Harley.
Hi ,
I have implemented Usecase -1  with Kerberos Session_latest.pdf ‏ reference.
I have implemented using Apache2.2.25 webserver and JBoss-As-7.1.0 Application servers in linux environment.
After configuration i tried to login through thin client /webclient but i am getting error :
Please share if you have document with Apache and jboss combination.
@GLeven I am facing the same problem. Have you figured out the solution for this ? Thanks!
Does someone has found a solution of this task ?
Hello Everyone
Is there any update on this issue. currently i am facing the same issue for TC11.4 with .net based server manager and TCSS(JBOSS).
As per GTAC Document :- Configure IIS reverse proxy for Security Services login service
Error message is :- configured behind gateway but no UserID provided. See Administrator
