STEP conversion from TEAMCENTER
Hi guys,
I've seen several posts about this but none of them helped.
I have a simple task to do.
In the company one Teamcenter user is the guy who is sending NX parts as STEP to their suppliers.
They want to do it by exporting the file as STEP from UGMASTER in Teamcenter.
How can we do this?
Cem
Re: STEP conversion from TEAMCENTER
First you need to have a translator from NX to STEP. After this you can implement this by using dispatcher. Dispatcher with the correct translator can be called from the top menu. A better way is to include it in your workflows
What do you mean by NX to Step? There's NX to JT, NX to CGM supplied with dispatcher.
Where do we get NX to Step? Do you mean the internal NX to Step converter within NX?
Saygılarımla,
Cem ALPAY, Yönetici
ÜÇGEN YAZILIM LTD. ŞTİ.
TEL: 0216 550 52 06
[cid:image001.jpg@01D261F2.4F8398D0]
I'm not a NX expert, but you could use the internal NX to STEP convertor.
The problem is, we want to do the STEP conversion from Teamcenter, not NX.
A user will find an Item which has an NX dataset in it, then select it and convert to STEP, that's what we actually need.
Saygılarımla,
Cem ALPAY, Yönetici
TEL: 0216 550 52 06
[cid:image001.jpg@01D2627E.76D15F80]
If you use Dispatcher it will start NX on your server and do the translation in the background
If You want to do this without NX (directly from command line or from visualization), you need a STEP translator
VS22171 - JT Bi-Directional Translator for STEP
Best regards
Bernard Pacula,
CAMdivision Sp. z o.o.
Consultant PLM/System Architect
So if I sell this to my customer, can this be configured and done within the dispatcher?
Best Regards,
Cem ALPAY, Managing Partner
UCGEN YAZILIM LTD. STI.
TEL: 0216 550 52 06
Yes,
But ask GTAC how to configure this translator in dispatcher.
Best regards
Bernard Pacula,
Thanks!
Saygılarımla,
Cem ALPAY, Yönetici
TEL: 0216 550 52 06
[cid:image001.jpg@01D270D5.ACBF0330]
