SWIM Silent Uninstall 11.3
Anyone know of a way of uninstalling SWIM 11.3 silently?
Found this IR for 10.1
I can launch the uninstaller form a cmd line, but it just opens the GUI.
I've got 30 odd clients to uninstall :-(
Rich
Richard Bennett
Prospect PLM
9 REPLIES 9
Re: SWIM Silent Uninstall 11.3
The Teamcenter Manager for SolidWorks Installation Guide (in %SWIM_DIR%\InstallationGuide.pdf) has a section for uninstalling (pg 56 of 62 in mine) and lists the commands needed to perform it which you can put in a bat/cmd script.
Evaluating: AW 3.4
I do this at every upgrade. Below is syntax for SWIM10 as I do not yet have a need to uninstall our SWIM 11.4 env.
REM: ============================================================================
title Uninstall SWIM 10.1 ^(1 of 6^)
REM: ----------------------------------------------------------------------------
cls
echo.
echo Uninstall SWIM 10.1
set REGKEYID=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Teamcenter Integration for SolidWorks Version 10.1.0
set REGKEYSTR="%REGKEYID%"
reg query %REGKEYSTR% >nul 2>&1
if %ERRORLEVEL% EQU 1 (goto swim-end)
echo Removing SWIM 10.1
call "D:\MICAxPLM\SWIM101\SwimUninstallerData\Uninstall Teamcenter Integration for SolidWorks Version 10.1.0 Installation.exe"
if %ERRORLEVEL% EQU 0 (
echo WARNING: Could not complete uninstall of SWIM! Will now force it. Take THAT SWIM!
reg delete %REGKEYSTR% /f
:swim-end
if exist D:\MICAxPLM\SWIM101 (rmdir /s /q D:\MICAxPLM\SWIM101)
if exist "C:\Users\Public\Desktop\Teamcenter Integration for SolidWorks.lnk" (del "C:\Users\Public\Desktop\Teamcenter Integration for SolidWorks.lnk")
if exist "C:\Users\%USERNAME%\Desktop\Teamcenter Integration for SolidWorks.lnk" (del "C:\Users\%USERNAME%\Desktop\Teamcenter Integration for SolidWorks.lnk")
echo Done.
Larry Carpenter, P.E.
Great @LarryCarpenter, this looks like just what I want.
Thank you very much!
Rich
Richard Bennett
Prospect PLM
Hi @LarryCarpenter, I spoke to soon.... Its not silent....  I dont want to interract with the uninstaller...
Rich
Richard Bennett
Prospect PLM
Looks silent to me. Can you explain more about interacting with the uninstaller? Screen shot?
Evaluating: AW 3.4
I have to select "Uninstall"....  I just want it to do it silently - no interraction whatsoever!
Rich
Richard Bennett
Prospect PLM
You can create an "answer" file for any exe (*.iss).
http://unattended.sourceforge.net/installers.php
For setup.exe:
Setup /r /f1"C:\Temp\Setup.iss"
Setup /s /f1"C:\Temp\Setup.iss" /f2"C:\Temp\Setup.log"
Evaluating: AW 3.4
I could never get the ISS thing to work with the SWIM install. It's some sort of custom installer tool.
If you don't want any GUI then the only other option that's worked for SWIM is to manually delete the registry entries and folder structure in a script.
Ah, I thought this was the case. But had to ask to be sure.
Rich
Richard Bennett
Prospect PLM
