Save as items in bulk mode with item id incremental
I have thousand items with same data.I need to do save as operation in bulk mode.is it possible?
3 REPLIES 3
Re: Save as items in bulk mode with item id incremental
Good afternoon, I can offer you to try the following algorithm:
1. Create a temporary assembly element, in the structure manager, include in the assembly all the elements that you need to save as
2. In the structure manager, make a duplicate assembly using File -> Duplicate
3. Delete the temporary assembly element and you must have copies of the elements with the new identifiers
@ArthurRM.
Thanks for bom duplicate explanation. My scenario is bit different.For example, I have customItem and its id pattern is R-001, i have already created that item and i need to save as this item till R-009.Is it possible?
Good afternoon, I apologize for the late reply, when you duplicate the assembly, you can manually specify the ID for each incoming component (I think this is the easiest way):
What else can I offer you:
1) As one of the options for you to offer to export all your components, for example in PLMXML change their identifiers in the PLMXML file and import back into Teamcenter.
2) Write your ITK utility
